rear hub removal any ideas?
Hi, Trying to remove the rear hub but the nut tat is holding it in place keeps spinning. I have tried to put the wheel and axle back on to help keep it from moving but no such luck. Any good tricks on how to do this?
- rear hub.jpg (183.45 KiB) Viewed 2939 times
- Muddy
G'day chris305
The best time to loosen that nut is when the rear wheel is in place and locked up by the axle, but that might a bit hard for you now.
Have you tried putting a bolt thru the rear hub with a large washer either side and locking that up. Hopefully with a bit of penetrating lubricant on the large nut, this would hold it in place while you get it loosened.
Hope that works for you.
Regards
Muddy.
Regards
Muddy.
Thanks.
Regards
Muddy
'64 C72
'63 C72
Regards
Muddy
'64 C72
'63 C72
