CB77 OIL COMING UP TACHO CABLE
Is it normal for oil to come up the tacho cable or have I got a breather problem. I noticed that there is no seal on the drive gear to stop this.
Re: CB77 OIL COMING UP TACHO CABLE
The cable has a special seal at the head connection. ...............lm
Hondapete wrote:Is it normal for oil to come up the tacho cable or have I got a breather problem. I noticed that there is no seal on the drive gear to stop this.
Thanks LM, my seal is not working if that is the case as oil had got into the the head. When I cleaned the cluster there was a considerable amount of oil on the tacho side of the case.LOUD MOUSE wrote:The cable has a special seal at the head connection. ...............lm
Many thanks
