Signal not flashing
Robbie63
Signal not flashing
Post by Robbie63 » Thu Apr 28, 2016 6:43 am
When I put my signal light on they light up as they should,they just don't flash but I can hear the flasher makin a horrible noise. I have been taping it in an attempt to get it to work,but no luck.just woundering if this sounds like a bad connection or needin a new one.thanks for any advice. Rob
revlover
Post by revlover » Thu Apr 28, 2016 5:05 pm
I would say it's the contacts inside the flasher are corroded or burned through. Try substituting a known good flasher in its place. Beware not all thermal flashers are suitable for small loads like only two bulbs on a cycle. Newer electronic units work well for varying loads, smaller loads or LED bulbs.
casamere
Post by casamere » Fri Apr 29, 2016 2:21 pm
Only way I could get my flashers to work on the original flasher unit was to fit 5w bulbs. I fitted a modern relay unit that fitted into the original cradle and fitted 15w bulbs and everything works perfect.
Robbie63
Post by Robbie63 » Fri Apr 29, 2016 7:17 pm
Thanks for the quick replies. I will try a different flasher. Cashmere that picture of your benly is the nicest I have seem simply pristine .well done
Robbie63
Post by Robbie63 » Fri Apr 29, 2016 7:20 pm
casamere
Post by casamere » Sat Apr 30, 2016 2:16 pm
Robbie63 wrote:Thanks for the quick replies. I will try a different flasher. Cashmere that picture of your benly is the nicest I have seem simply pristine .well done
Thanks Robbie63 nice to be appreciated, I love it.
Robbie63
Post by Robbie63 » Thu May 12, 2016 10:42 am
Got a different flasher from Canadian tire,installed it and works great.thanks for all the help
