REPLACE CONDENSER CA77 Dream
roadrunner
Post by roadrunner » Mon Feb 29, 2016 4:50 pm
Can somebody tell me how to remove the condenser off the manifold.it would be most helpful
brewsky
Post by brewsky » Tue Mar 01, 2016 6:56 am
You have 3 choices...
1. drop the engine
2. TRY to remove it with a small 90 degree phillips (and risk a trip to the local mental hospital)
3. cut the wires, leave it where it is, and add a new one somewhere else (like under the side cover near the coil.
The original location was obviously chosen by a devious sadist who slipped thru Honda's background check system!
roadrunner
condenser
Post by roadrunner » Tue Mar 01, 2016 8:19 am
Brewsky your to funny,i well take #3 i have already been to the Mental Hospital last week.thxs for the best choose.
brewsky
Post by brewsky » Wed Mar 02, 2016 6:05 am
Note the old condenser also serves as the wire from the coil to the points, going from the coil all the way to the front of the engine, and then back to the points.......so, unless you buy an exact replacement condenser, you may want to save the old wires with the heat shield section for re-use.
roadrunner
Condenser for 1965 Honda Dream 305 CA77
Post by roadrunner » Wed Mar 02, 2016 11:44 am
I didn't know that thats good to know Brewsky thank you,maybe droping the engine might be better way to go. i'm not sure. i'll have to think this over more thxs again.
