1964 CL 72 oil leak
Get a 16mm x 1.5 bolt (sometimes the rear spindle will work) and screw into the thread inside the rotor. Do the bolt up tight, then tap the head with a hammer. The rotor shoudl come loose.
Thanks, Just tried that. Threads on my rear spindle are finer than the threads in the shaft. Guess I will go shopping for the right unbolt.....unless u have other ideas.....
I thought the rotor was threaded onto the shaft, but from your reply the rotor must just slide on the shaft and is properly located via a key way, so I will need to be careful not to put it back on 180 degrees off, correct?
Found a bolt! So now the rotor is off. I'm assuming the seal is behind the black metal cover. The cover is well sealed with a nice bead of grey silicone leaking through the gap, but the oil seemed to be coming from behind the stator.
Does this cover just pry off?
- image.jpg (104.89 KiB) Viewed 2776 times
The black part you can see is the seal. I can see some drillings in the shaft next to the seal. If you have a CL those shouldn't be there as they lubricate the starter sprocket bearing on a CB. Can you poke anything in to those holes? How far?
I was able to probe a small diameter stiff wire 1.75 cm straight down in to the shaft. The hole is at 12 o'clock. The other image that appears to be a hole is bit of dirt.
Hope oil I can't leak out of that hole...no starter to lube up on this bike.
Now that I open my pack of seals I see one that matches up to that large black disk!
Any ideas/advice on prying this seal out?
