ca77 gear shift fork question
choctaw
Post by choctaw » Tue Jan 12, 2016 7:10 pm
Here are 3 pictures of my forks the one on the left has a burnt spot. Is this ok? the tips are in really great shape and the gear shift drum is really nice and falls into specs easily.also the thickness on the worn areas of both,do they need to be built back up? thank you Mike
Re: ca77 gear shift fork question
Post by LOUD MOUSE » Tue Jan 12, 2016 10:33 pm
Please show the sides of the rollers and the point nearest the end of the drum. .............lm
choctaw wrote:Here are 3 pictures of my forks the one on the left has a burnt spot. Is this ok? the tips are in really great shape and the gear shift drum is really nice and falls into specs easily.also the thickness on the worn areas of both,do they need to be built back up? thank you Mike
