63 Honda Dream
gearhead3275
63 Honda Dream
Post by gearhead3275 » Thu Nov 05, 2015 6:15 pm
My 63 Dream won't start up without the use of starter fluid and won't idle on its own. Once the bike is started it will run great as long as your using the throttle slightly to keep it running.. Any suggestions. Gear
DianneB
Post by DianneB » Thu Nov 05, 2015 7:44 pm
Sounds like low compression. Have you checked it?
gearhead3275
Post by gearhead3275 » Thu Nov 05, 2015 8:44 pm
No I have not checked it. I'll go buy a compression tester tomorrow. Do you by chance know what the range is supposed to be?
DianneB
Post by DianneB » Fri Nov 06, 2015 3:17 am
The manual says 99.5 PSI using the kick starter but anything over 60 should be run-able for an engine this age. My '67 needed new rings and the cylinders honed to get the compression back up.
revlover
Post by revlover » Fri Nov 06, 2015 5:49 am
Also could be a blockage in the slow jet in the carburetor.
brewsky
Post by brewsky » Fri Nov 06, 2015 6:03 am
revlover wrote:Also could be a blockage in the slow jet in the carburetor.
+1
Very common and hope that is it!
gearhead3275
Post by gearhead3275 » Fri Nov 06, 2015 8:28 am
I'll get the carborator expanded view out see where the slow jet is found and look into that as well. Thank you...
