Tail Light Stuck on Bright.
deafanddiabetic
Hey everybody,
I've mostly got the CA72 Dream together after an engine and transmission rebuild and a new COAt of paint. I'll post pictures when it's together!
I marked all my wiring harness leads before disassembly so that I could just plug and play when putting it back together. I decided to solder and seal all the wires to be safe.
My only issue is that my tail light is stuck on bright, or acting like it's "pulled". I tried switching the wires at the tail light brake lever switch, but that didn't make a difference either. Could I have gotten the two wires going to the tail light switched up?
It was working for a short while, like had it's normal running light, then I pulled the lever switch down and it went bright like it's supposed to, now it just stays bright.
Not sure what the issue is?
1964 CA72
1974 BMW R75/6
1969 CL450
1974 BMW R75/6
1969 CL450
deafanddiabetic
Definitely clean and test it. There isn't much below the switch that's complicated enough to go too wrong. The little arm below the switch is attached with a shouldered bolt, so I don't think it could get rusty enough to lock up, but give it a look too.
Plenty of used switches on ebay. If you want new and don't mind non-stock, you can search for non-Honda replacement, like this: http://www.ebay.com/itm/Emgo-Rear-Stop- ... 59&vxp=mtr Cheap at $9.95 with free shipping.
- IMG_0954.JPG (78.69 KiB) Viewed 2785 times
deafanddiabetic
roadrunner
stickey brake switch
i had the same problem with mine as the guys are saying i gave mine a good cleaning and it works fine.
deafanddiabetic
