                    Cb72 fork swap
Cb72 fork swap
Can anyone tell me if there are any forks that will swap directly into my 65 cb72 yolks and will use the original wheel. Mine had a plastic front mudguard held on by jubilee clips. Or should I restor my forks and weld some lugs on to mount the mudguard properly.
This is a race bike not original.
- image.jpeg (270.91 KiB) Viewed 5738 times
				OldScrambler
Re: Cb72 fork swap
Tunster
Welding brackets to those forks would need care as you might distort the tubes.
Forks from a later Honda, such as a CB250 / 350, could be fitted but they still wouldn't have a bracket for that particular mudguard. My racebike has a plastic mudguard with CB350 (I think) forks.
The steel CB160 / S90 front mudguard is popular for the '60s Honda GP look. See pic below....
Fitting your wheel to another set of forks isn't going to be a problem. The 15mm spindle size is fairly common. Even the GT750 Suzuki wheel in my racebike has a 15mm spindle.
Tunster wrote:Can anyone tell me if there are any forks that will swap directly into my 65 cb72 yolks and will use the original wheel. Mine had a plastic front mudguard held on by jubilee clips. Or should I restor my forks and weld some lugs on to mount the mudguard properly.
- CB72 with_CYB_parts_fitted small.jpg (114.84 KiB) Viewed 5689 times
'60 C77 '60 C72 '62 C72 Dream  '63 CL72
Cb72 forks
Thanks G-man I will see what's about at Stafford show. Distorting the tubes was a concern and the expensive of restoring them overall. I like the shorter mudguard but didn't like the jubilee clips. Thanks for the advise.
