Hi guys,
Great forum here, i'm a new to the forum.  I have a quick question that if answered might help a 1964 honda dream land in my garage by the weekend.
I've found a 1964 Honda Dream that i'm interested in buying for restoration.  It has a valid title with the serial number on it, but the serial on the motor is different than that of the title.  Is this normal?  If so, is there another place on the bike that the correct serial number is located?
I just want to make sure before I purchase it that the title matches the actual bike i'm buying:-)
Thanks,
Scott
                    Where can I find the serial number on a 1964 Honda Dream
It is on the lower left side of the frame near the footpeg...might need to wipe some dirt/oil off to see it.
If the last 3 numbers are within 200, it probably is a matched set. When you find it, post both and someone will tell you for sure.
Welcome to the forum! Show us some pics!
						Help with serial #
Just picked up a 305 w/engine # CA77E-102194M but cannot locate the serial # on the frame.  Any suggestions on where to look would be appreciated.
Z
						Z
Re: Help with serial #
It's located low on the left side of the frame, in the area behind the left foot peg and the kickstand. You might have to wipe off the grime to see it.Z wrote:Just picked up a 305 w/engine # CA77E-102194M but cannot locate the serial # on the frame. Any suggestions on where to look would be appreciated.
Z
Thanks for the prompt reply. Now I can get a title!Seadog wrote:It's located low on the left side of the frame, in the area behind the left foot peg and the kickstand. You might have to wipe off the grime to see it.Z wrote:Just picked up a 305 w/engine # CA77E-102194M but cannot locate the serial # on the frame. Any suggestions on where to look would be appreciated.
Z
