S&K pistons
oldbikedude
Re: S&K pistons
I have used them and sold them.
Other than the wrist pin hole is a bit tight (it can easily be enlarged to fit the pin) they work well. ......................lm
oldbikedude wrote:Anyone have anything to say about them? Good or bad?
Tim Miller
Re: S&K pistons
They need more clearance than ART's. I always go with .0025" on S&K's. This could be why the pin bores are a little tighter. But if sleeves are not tight it will likely sieze no matter what you do. Oh yeah, get a timing light and make sure the total ignition timing is correct, too.
Tim
Tim
Re: S&K pistons
AS usual I see you are jamming!!!!!!!!!!!!!!!. ............lm
Tim Miller wrote:They need more clearance than ART's. I always go with .0025" on S&K's. This could be why the pin bores are a little tighter. But if sleeves are not tight it will likely sieze no matter what you do. Oh yeah, get a timing light and make sure the total ignition timing is correct, too.
Tim
oldbikedude
Tim Miller
What I'm saying is if your cast iron cylinder sleeves aren't tight enough there's no place for piston heat to transfer. And that can cause piston to sieze.
S&K's do seem to grow more then stock. So, yes the alloy must be a little different. I use .002 for stock and like I said .0025 for S&K's. Hope this helps.
Tim
Tim
oldbikedude wrote:I am not sure I understand this statement & are they different composition from stock pistons?But if sleeves are not tight it will likely sieze no matter what you do.
