apexcycle mufflers?
Post by LOUD MOUSE » Sun Oct 14, 2007 3:20 pm
Check his feedback and ya can bet ya better not complain cause he'll give ya negative feedback and claim ya are picky or don't have a clue.. ......................lm
steven0356 wrote:I went a head and got the apexcycle mufflers. The descriptions you read on this and other forums are accurate. The The workmanship on these mufflers are questionable at best, but they are only $214.00. I guess you get what you pay for. A rusted set of stock mufflers just sold on ebay for over $300.00. These will do for now.
Steve
piecutter
Post by piecutter » Wed Oct 17, 2007 9:27 am
As far as holes lining up, I've got an original Honda set that's pretty darn off on one side as well. I have to use a pry bar to get the bolt in the left side hanger bracket!
joeweir1
Post by joeweir1 » Mon Oct 22, 2007 7:34 pm
I got the same set of mufflers from an Ebay seller from Thailand for half the price that Apex sells them for.He must get them from there in my opinion.Had an issue with one side not lining up quite right, but work on my everyday rider.
wombat200
Post by wombat200 » Thu Oct 25, 2007 7:53 pm
I have a set too, but like above, boguth them direct from asia at only $99.
I intend to have the chrome removed (it's flaking anyway), pull out some of the dents & tidy them up, then re-chrome. That will add them up to about $250, but they aren't too-bad, looks wise, and will do for a non-original bike.
Dogsbd
Post by Dogsbd » Fri Oct 26, 2007 11:18 am
Apex has a new style on eBay now:
http://cgi.ebay.com/ebaymotors/_W0QQitemZ250180321111
I think I like these better than their other style.
But $250??? That is crazy for what is essentially a chrome plated, slash cut tube with one bracket welded on!
Here is a business opportunity for someone if these sell at $250, because I bet someone on this forum can build 'em and sell 'em for much less!
Post by LOUD MOUSE » Fri Oct 26, 2007 11:30 am
Could it be the tip has a large hole in it?. ...............................lm
Many years back I bought a CL77 for parts. It came with stock pipes and some baffles in each. When I was able to remove those baffles I found them clogged/coated/layered with carbon soot. The baffles were fro the C/CA/CB72/77 bikes and with the holes on the outside only the exhaust wasn't able to get out. The correct CL72/77 baffles have a smaller center and 2 locating areas to keep them in the pipe and not rattle. Take a good look at the inside diameter of the pipe then look at the baffle and you tell me this won't give 95% back pressure. .......................lm
Dogsbd wrote:Apex has a new style on eBay now:
Vince Lupo
Post by Vince Lupo » Tue Dec 11, 2007 4:23 am
Heck if you're going to spend that much money, you could get two sets of EMGO mufflers from JC Whitney. They are definitely better quality than the Apex mufflers, look right, sound right, and definitely flow better. The only thing to watch out for is the mounting channel on the backside of the muffler....they could fracture over time, but I'm sure it would be an easy fix if they did.
Or, if you wanted to be super cool, get a pair from Armours or Norman Hyde in the UK!
