Timing chain marks
gbyoung2
Yes, understand the position of the master link is irrelevant; obviously, cam timing mark is.Hahnda wrote:No need to align the master link with the mark.
Mark must be perpendicular to top surface. Its off by at least one tooth. Maybe more.
I'm thinking it's off by one. If you mentally rotate the cam CW, paying attention to the "0", one tooth would put it in alignment with the center line of the crank, up through the engine, and the center line of the cam. That's the way I'm visualizing it, but proof will be once I swing the chain up over the sprocket and see where the marks fall.
On this particular engine, it appears that the "0" mark is dead center of the horizontal flat of the advancer plate. That being said, when everything is aligned properly, that flat should be parallel with the top of the head. Again, we'll wait until the chain gets put in place and see what we have.
http://gbyoung2.smugmug.com/Motorcycles ... 014-X2.jpg
http://gbyoung2.smugmug.com/Motorcycles ... 016-X2.jpg
gbyoung2
Finally had a chance to get back on the 305. Feel pretty comfortable with the cam timing, but would like a final critique before I fully install the master link and button it up - just to be sure:
https://gbyoung2.smugmug.com/Motorcycle ... 004-X2.jpg
https://gbyoung2.smugmug.com/Motorcycle ... 003-X2.jpg
TIA
TIA
CAM CHAIN TIMING
You have it correct. ................lm
gbyoung2 wrote:Finally had a chance to get back on the 305. Feel pretty comfortable with the cam timing, but would like a final critique before I fully install the master link and button it up - just to be sure:
TIA
gbyoung2
Re: CAM CHAIN TIMING
Good!LOUD MOUSE wrote:You have it correct. ................lm
TIA
Thank you for looking.
Guy
You are welcome. ...........lm
gbyoung2 wrote:Good!LOUD MOUSE wrote:You have it correct. ................lm
TIA
Guy
OldScrambler
