Thanks LM for your reply,LOUD MOUSE wrote:HERE I GO AND IF I OFFEND YOU, YOU MAY BE THE PERSON THIS IS ADDRESSED TO!
I'm amused by some things I see that are Over Kill to fix or repair a simple part in these engines when plenty parts are out here and $$$ seem to be the Road Block. to some ?????????????????
As I see what comes next I never see any $$$ saved.
To me it seems that in the end more $$$$ and time are spent for simple repairs.
I am impressed at how some are so capable to use tools or have parts made at machine shops that the average sole who wants to JUST GET ONE RUNNING AND RIDE ABLE will never have but salivate (drool) at the process shown on this forum.
Yes I'm impressed on how a SPECIAL FITTING can be made to allow a Bearing that doesn't cost all that much can be changed but WILL BE SPECIAL in ones engine.
I shutter to wonder how much if any $$$ you save with all the things I've observed in the last months.
I can and have rebuilt several REALLY SORRY engines for +- $950.00 US and the sad thing with this the cost to ship is usually near $100.00.
If I wasn't so lazy I'd show all the simple ways to take these engines apart and then how easy they go back together.
Special Tools! Hammer, flat chisel, vise grip pliers, HAMMER DRIVE to loosen/remove Screws jis #3 screwdriver, long point punch, wood to put on the 2 Deadheaded Nuts at the engine center to split the cases, Bass rods to knock the cams out of the head. Sharp Putty Knife to remove gasket maternal.
Probably the tool most will not have is a Torque Wrench but OLD FOLKS have learned how to KNOW WHEN THAT NUT/BOLT is good and tight and will DO THE JOB! I HAVE 3. OTHER MAY NOT!
What allows me to be happy as I rebuild engines is that I understand "IT'S JUST A MACHINE" AND PAYING ATTENTION TO WHETHER A PART IS GOOD OR BAD is #1.I don't do things to fix a non existent problems or Puff Up my Chest with SPECIAL REPAIRS when the very simple HONDA parts are still out here and as many of you know I sell them at reasonable prices.
Most of you who I address this diatribe to have purchased HARD TO GET PART from me.
ENOUGH!!!!!!!!!!!!!!!!!!!!...............lm
SMBH wrote:Alloy, machine shop said it would be best., they made it very tight so I will put the bearing in the fridge and use a hot air gun on the sleeve to fit it and some bearing lock.G-Man wrote:Mike
That's the route I was going to take. Steel or alloy for the sleeve?
Sorry I didn't get around to it for you yet......
No problem Graham I had to have a new first gear bush made infact I had two made and they made a very nice job of them, so I got them to made the bearing sleeve while they were at it.
Also looking at replacing the other side with a 6206 STD bearing and sleeve.
While I have your attention the right side outer bearing the smaller of the crank shaft bearings 30 x 62 x 16 has a hole for lokating the knock pin, the hole in the bearing on my bearing is 6mm offset from centre and the knock pin is stepped down to 5mm so when the bearing is installed there is a lot of play is this so ?
Also the oil hole is covered when the bearing is installed and the inner side of the bearing is sealed not allowing oil into the bearing so all that is left is the very small channel by the bearing, im thinking of removing that inner seal.
Your thoughts on it would be very welcomed.
I put up the posting hoping to help any one that have a problem obtaining the very hard to get here in the UK crankshaft bearing over the pond in the land of plenty more Honda's were sold and it seems to me there are so many more parts.
Some companies will not ship to the UK.
When was the last time you looked at Ebay for a crankshaft bearing for a CB72/77 give it a try.
Now if it BSA or Triumph parts then we have so many over here were they were built.
Torque Wrench I do have some spanners. (that my friend is a joke)
