bullet connectors
bullet connectors
Is there a source for the proper bullet connectors for the 305's? The ones I find in the store are larger. I found a couple headlights that match my CL77, but the bullet connectors on them are smaller. I could use them for other repairs as well.
63 CA78
s2000erick
They have the larger and smaller connectors, http://www.vintageconnections.com/
Got the bullet ends and sleeving today. Ends work perfectly. The sleeving was a perfect size match to replace the cover for the wires to the light switch. I also got some of the larger size and replaced the cover on the main harness from the headlight to the coils. The old one was stiff and broken in three spots, this is flexible, should last much better. I'll probably use some on my CA77 harness where it's bad as well.
63 CA78
