Wanted early CL77 seat pan
Need early CL77 seat pan, willing to buy or trade later CL77 seat pan with the front rubber mount.
OldScrambler
I have several...............when you say early..........I assume you mean the '65-'66 type with the wrap-under seat strap. I don't need the later style. Pan only........no padding or trim........$70 shipped from Wisconsin. It will need paint and suggest you fit it to your frame first to be sure of straight back mounting legs and battery clearance up front.
Wanted early CL77 Seat
I have a complete early seat with strap & trim. Good for a rider or break it down & recover.
Front cover clips have come loose, looks solid with original cover. You also get the rear
"flip up" lost in a lot of rebuilds.
Due to the box weight & Postal lines, I'm asking $95 shipped to your door. Thanks, Scram64
- 2014_0728CL-Seat0005.JPG (229.93 KiB) Viewed 3528 times
- 2014_0728CL-Seat20004.JPG (209.08 KiB) Viewed 3527 times
im having the same issues with the email on here. im working on a seat right now if you still need one. i restoring one so it will look decent once its done
search user name in ebay " charlesmineo " and you can others i completed already. ignore the pricing on there. i give special pricing outside ebay
