Side stand length
Woodsie
Side stand length
Post by Woodsie » Mon May 25, 2015 6:44 pm
My CA77 appears to lean more than should when on the side stand. Not having seen another Dream it may be correct, or are there different lengths of sidestands on different models?
brewsky
Post by brewsky » Mon May 25, 2015 7:52 pm
What size tires do you have? Oversize will cause extra lean.
Also bending from abuse will cause the same.
They all are the same length as far as I know.
Woodsie
Post by Woodsie » Tue May 26, 2015 9:17 am
Thank you.
brewsky
Post by brewsky » Tue May 26, 2015 9:42 am
Your welcome....many of the used bikes I have had suffered the same problem.
I usually keep a small block of wood in the saddlebags with me for that very reason, as well as when I have to park in a soft area.
Hamamatsu Nippon
Post by Hamamatsu Nippon » Tue May 26, 2015 11:12 am
Another symptom I have seen too is the bolt hole wearing oval from a damaged/loose bolt.
1967 CA78
1965 CM90
Soichiro Honda
