Although the obvious thing to be doing this weekend was getting the engine finished, I realised that I needed to get some parts off to the chome platers. They do excellent work but that means that their turnaround time is in excess of two months. With the amount of travelling that I do it is necessary to plan ahead. I had one or two small bits ready to go but, before I could pay them a visit, I wanted to get some early damper bodies cleaned up.
The correct rear units for these bikes are the ones with aluminum covers top and bottom, but these are not very durable. I have restored a set but they will be kept for 'best'. If I am using the bike I will fit some slightly later rear shock absorbers. I picked up a rusty set with my '62 project and Alan Curtis had a set which needed restoring also. These 'not so early' ones are still not the mainstream type that Honda fitted later. The top covers are steel and the bottom clevis is similar to the very early ones - cast into the body, rather than welded on.
Unfortunately the other 'not-so clever' feature that Honda included was an aluminum screw which holds the damper rod in. All the others are steel and relatively easy to remove with tools that I have made. These aluminum ones were all already butchered by previous owners and to compound the crime that had all been nastily punched at the top to secure the screws.
I did manage to find a spare set on eBay for just $9.99 but they were just as bad as the ones I had. The chrome was a little better but that was the only consolation.
You can see the battered steel upper covers and here you can see the lower clevis..
Because the ends were damaged from the punch marks and the threads were all a mess I thought about cleaning up the threads in my lathe by screwcutting them but that is a risky business requiring careful set up and perfect alignment.
Then, I was idly searching eBay and came up with this: A giant 27mm x 1mm pitch tap from a supplier in China. I couldn't believe my luck. It was cheap and came pretty quick, too.....
Armed with this I was able to set the shock bodies up in the lathe in a fixture that I had made for dealing with CL77 dampers a while back.
Each body had to be individually trued up for running in the lathe but that was a minor problem now that I had the ability to clean them up nicely.
First job was to use that new tool to clean up the nasty threads.
Then I was able to clean up the end of the bodies by shortening them slightly. This involved removing around 3mm of the worst damage so that I could get them nice and square.
It's good doing multiple parts as most of the time is spent working out the method and getting things set up. I now have 3 sets of bodies. One for Alan. a spare set for my '61 bike and a set for my '62 CB72 which I am collecting parts for. They are now cleaned up sufficiently for Prestige Electroplating to do their magic.
The best bit for me is that I have managed to sort out all of that horrible thread damage. I still have to get 6 sets of innards ready for when the parts come back but I can take my time over that....
It will be nice if I can get them to look as good as the last two sets which are the type with alloy covers .......
