67 CL77 need new key, mine ready to break off
I'm looking for a new key for the ignition switch, mine is bent bad and ready to break, I found some blanks, but not sure that will help (who cuts them?)
The code I have on the key is 43F, I have not seen a similar code either.
Any help is appreciated.
-Forrest
-Forrest
Hi Forrest
The 43F is probably just a code to specify the profile of the key blank, not the specific key. Can you read a number on the lock?
A good locksmith should be able to use your key to cut a new one, even if yours is broken.
deafanddiabetic
That doesn't sound like a Honda number.
Either NA, NB or T follower by 3 or 4 numbers.
ugmold wrote:You had to have a blank right?deafanddiabetic wrote:I didn't have a key at all for my ignition, local KeyMasters made me one for $15. Just had to bring in the ignition tumbler for them, it took less than an hour.
I looked for the number on the tumbler it is 6VH43F.
I agree, it was stamped on the side, not the face of the switch.G-Man wrote:That doesn't sound like a Honda number.
