1964 CA77 Restoration
Post by G-Man » Tue Apr 21, 2015 9:14 am
I'll see what I have at the weekend and get back to you. I have more early stuff than late.
Post by Seadog » Tue Apr 21, 2015 9:58 am
G-Man wrote:I'll see what I have at the weekend and get back to you. I have more early stuff than late.
Thank you, G. I truly appreciate it.
Post by Seadog » Tue Apr 21, 2015 10:01 am
Found the reference to aircraft stripper and picked up a quart at the local auto parts store this morning. Just applied a coat of Klean-Strip. This stuff is powerful!
Ordered an LED tail light this morning also. A bit premature, I suppose.
Post by Seadog » Thu Apr 23, 2015 10:19 am
almost makes you cringe, doesn't it?
Post by Seadog » Fri Apr 24, 2015 12:04 pm
finally finished all the stripping this morning. I'm glad; I'm tired of it. I used more than a quart of stripper. Parts off to the painter on monday and I can concentrate on other things.
Post by Seadog » Mon Apr 27, 2015 12:57 pm
Dropped all stripped parts off at the paint shop today. I was happy to see that the rear fender had been beautifully repaired and that the frame and swing arm are in final primer, ready for paint. Progress at last.
Post by Seadog » Mon Apr 27, 2015 6:06 pm
On a whim, I decided to see if my starter motor would spin, so I connected it to my battery and, much to my surprise, it spun freely. I guess I'm surprised because it's covered in grease, grime and rust and looks so bad that I really didn't expect it to work.
I've started to clean it up and will have to do some research on how it should be finished. Maybe it comes apart.
The underside is all grease and rust
