1964 CA77 Restoration
I'm looking forward to it also, but it's going to be a long wait. I'll post photos when they finally get here. One disappointment already - Central Wheel could not powder coat the central hub area where there's normally gray paint. They couldn't mask it off. I told them to polish them.Steverino wrote:I'm looking forward to seeing your wheel sets when they arrive. These are the largest pieces I am aware of to make such a journey.
The folks at Central Wheel tell me that they ship to the U.S. "every day". Hopefully when they ship my wheels they won't take as long in U.S. customs as they did in the U.K. One week. I suppose they had to inspect them. I hope they were disappointed.
Worked on stripping the paint from the frame for the past couple of days. Finally finished the outside today. Lots of grinding to do though and the back fender is bent and cracked under the license plate frame. No other bad dents, but lots of rust in the side cover areas - especially the battery side. I really want the frame stripped, repaired and painted in advance of receiving my wheels.
- A bit of damage
- IMG_0629.JPG (150.31 KiB) Viewed 3851 times
- Bare naked
- IMG_0626.JPG (167.02 KiB) Viewed 3851 times
hotrodhendrix
deafanddiabetic
After stripping my frame I found those same license plate section cracks, and my rear fender was also totally separated up both sides near the shock mounts, probably from someone sitting too far back on the bench seat and going over a rough bump. Thankfully it was still attached across the top and a little welding and grinding smoothed out all the issues for me.Seadog wrote:Worked on stripping the paint from the frame for the past couple of days. Finally finished the outside today. Lots of grinding to do though and the back fender is bent and cracked under the license plate frame. No other bad dents, but lots of rust in the side cover areas - especially the battery side. I really want the frame stripped, repaired and painted in advance of receiving my wheels.
I've thought a lot about the color and while I'd like blue - I think LOUDMOUSE calls it "Future Farmers of America Blue" - I think I'm going to stay with black. This is not going to be a showpiece, but a regular rider and black will be easier to touch-up.hotrodhendrix wrote:Cool project. What color is it gonna be?
~James
I've spend days going from one auto body shop to another, trying to get the body work done. I found that not many were interested in the work, although they've all been intrigued by the bike. Yesterday I found two places that will do the work, but want to have it media blasted before they'll take it. None of them have the capability of blasting something as large as the frame.deafanddiabetic wrote: After stripping my frame I found those same license plate section cracks, and my rear fender was also totally separated up both sides near the shock mounts, probably from someone sitting too far back on the bench seat and going over a rough bump. Thankfully it was still attached across the top and a little welding and grinding smoothed out all the issues for me.
I've spent even more time trying to find a media blaster to do that work. I finally found one and delivered it today. 1 hour away from my home each way. They don't do round frame bikes, but, again, they were intrigued by the sheet metal frame and agreed to do it and the swing arm for $100. I left it there and hope they get to it soon. It will have to be primed immediately. As an aside, the owner told me he had a 1974 CB360 that had been sitting in his garage since 1975. He had no plan to ever ride it again. Unfortunately, he said he'd stored some pool chemicals on top of it and it was pretty rusty. Very sad.
More as it develops.
