Looking for a rear hub in good condition, mine is worn to where it's only using about 50% of the brake shoe.
Also looking for 2 bushing for the shock absorber mount on the swing-arm on the same bike.
66' CL77 Rear Hub
- moondoggers
66' CL77 Rear Hub
I have a good condition 36-spoke big-brake hub......no serious scratches..........no sprocket or brake-plate.......$45 shipped from Wisconsin to Arizona.
However, 50% shoe contact is not all that bad...........and will likely improve with some linkage adjustment.........unless the drum is actually worn that badly. I have been known to sand a few thou from the central sections of new pads for improved end-to-end surface contact.
I have used shock-mount bushes for the swingarm...........new would be better.
- moondoggers
- moondoggers
