Repurposed tool
Repurposed tool
These are originally meant for wood glue.
At least one of them has a new career as a mini mini grease gun.
- syringe 002.JPG (160.38 KiB) Viewed 2697 times
- syringe 001.JPG (133.17 KiB) Viewed 2697 times
And they are cheap, which is good because petroleum products will probably attack the rubber over time.G-Man wrote:Nice job. Every toolkit should have one!
The one with the curved tip has a very small hole. Would work with #90 gear oil, but probably not grease. The one I used for the speedo drive was cut to give it about 1/8" opening.
- Hamamatsu Nippon
Oh yeah, it will work with grease. Here I'm getting grease to the bearing by slipping under the cover with a large bore needle attached. You have to press really hard, but it works great.
- RD 012.jpg (153.33 KiB) Viewed 2653 times
1967 CA78
1965 CM90
Soichiro Honda
1965 CM90
Soichiro Honda
