R100 wrote:DAMN!
I put new ones in following the parts fiche.
Do you think I should take them out, reverse them, and pray it doesn't leak?LOUD MOUSE wrote:The one with the "O" goes on the pump.
The open one goes on top of the screen and against the lower engine case.
You don't need to worry about not having the open gasket as long as yours fits and doesn't leak. .................lm
R100 wrote:Just watched your "oil screen and pump" video.
The parts microfiche shows the gasket with the circular cut out going on the screen, and the irregular one between the screen and bottom plate.
I am still confused about it as mine had two circular gaskets.
1966 CB77 Frame-Up Restoration (or part-out if fubar)
If you haven't added oil I'd recommend you install them correctly. ............lm
Thanks LM. I will.
LOUD MOUSE wrote:If you haven't added oil I'd recommend you install them correctly. ............lm
R100 wrote:DAMN!
Thank you, and you're right - no chance of parting out at this point! :-DWaveblaster wrote:Come along way from thoughts of parting out!
FYI While riding around I found a significant steering dead spot that will need new bearings. I ordered roller bearings that are supposed to fit with just an additional spacer, and will probably do the work this upcoming weekend.
I started on my corroded fuel tank - trying to decide whether to finish it myself, or farm that work out to a fellow Ohio restorer.
I ordered "bullet" electrical connectors to start cleaning up the wiring. I'll take that opportunity to go through every connection with dielectric grease.
Little by little...
Here you go....
http://www.davidsilverspares.com/CB77-305/part_198082/
http://www.davidsilverspares.com/CB77-305/part_229068/
