Lighting/Wiring questions.
R100
Post by R100 » Mon Sep 29, 2014 12:38 pm
Please bear with me on this. My first CB77 and it came to me with a cobbled together jumble of wires that go in the headlight shell.
1. Looking at the wiring diagram I see the gr/wh wire from the headlight bulb socket should go to ground. Does it go to the gr/wh wire on the back of the speedo? The speedo sits in a rubber ring so how does it ground? (don't have the long spring shown inside the bucket on the microfiche).
2. Not sure where the neutral light goes. I see a place for it at 12 o'clock (back of the speedo) and what looks like remnants of a small lens on the front (can't tell what colour it was). If that is where it goes, what is the indicator light (blue?) on the outside of the headlight shell for?
speedo 001.JPG (131.42 KiB) Viewed 3041 times
speedo 002.JPG (132.52 KiB) Viewed 3041 times
Hoosier Tom
Post by Hoosier Tom » Mon Sep 29, 2014 12:42 pm
Where you have the circle is where the high beam indicator bulb goes. The neutral light goes in the headlight bucket between the headlight and the speedo.
HT
Post by G-Man » Mon Sep 29, 2014 12:43 pm
Blue lamp is neutral indicator.
The wire on the speedo is for grounding the case to the headlamp shell.
R100
Post by R100 » Mon Sep 29, 2014 1:15 pm
Hoosier Tom wrote:Where you have the circle is where the high beam indicator bulb goes.
HT
I don't see a high beam indicator bulb in the wiring diagram?
Hoosier Tom wrote: The neutral light goes in the headlight bucket between the headlight and the speedo. HT
So neutral light is blue on the outside of the shell over to the right?
R100
Post by R100 » Mon Sep 29, 2014 1:22 pm
G-Man wrote: The wire on the speedo is for grounding the case to the headlamp shell.
Have I got this correct?
Headlight shell, being mechanically fastened to the bike, is grounded, and can therefore provide a ground connection to the speedo body.
Post by G-Man » Mon Sep 29, 2014 2:10 pm
Yep!
R100
Post by R100 » Mon Sep 29, 2014 2:15 pm
G-Man wrote:Yep!G
Thanks.
This electrical stuff makes dental appointments look like fun.
