Electric start help
Bobs305dream
Electric start help
Ok so I'm working on the 64 dream 250. I can't get it started with the kick start, just rebuilt the carb and I've been trying to get it to kick over. There's no battery in my bike, I read somewhere that there's battery problems between the 6 and 12v bikes that were built in the earlier years. Somebody I was talking to told me to put jumper cables going from my car battery (running) and connect the jumpers to the leads on the motorcycle, and it will help get the electric start kicking over. I'm afraid of cooking the electronics...I am going to buy a new battery but once again idk what battery to get for the 64. Any help would be appreciated.
Hoosier Tom
The battery you seek is a JB-2 found on eBay. Use the search feature at the top next to the log in/log out script. Many of the questions newbies ask can be found by using the search function.
http://www.honda305.com/forums/agm-batt ... %20battery
Also learn to use the parts diagrams from CMS in the Netherlands.
http://www.cmsnl.com/honda-ca72-dream-t ... partslist/
Parts changed at certain times and most times these will be reflected with frame number references.
HT
HT
Jump Start
All the C72/77/78 are 12 volt. C71 dry sump, 1960 and prior are 6 v. IIRC.
As I understand it a car battery has too much amperage for the original selenium rectifier so you shouldn't use it to jump your Dream. I think you would be okay using a battery charger set at no more than 10 amps. Anybody disagree?
Or, you can use a charger set on 2 amps and kick start it.
I also think I remember reading somewhere that a Dream will start without the battery in it. It seems like I read that in the owners manual.
