CA77 305 frame changes ?
I have just purchased a 1961 Honda CA77 305 which is largely complete and relatively clean except....someone in their infinite wisdom thought it would be easier (so it would appear) to cut off the tail end of the frame after the fender braces rather than repair it. Could anyone elaborate as to what changes there were to the frames throughout the years this bike was made? My only viable options would be to either buy another frame or heaven forbid cut up another one and weld in the new section. Any suggestions?
- CAM01030.jpg (375.43 KiB) Viewed 3092 times
- CAM00969.jpg (437.27 KiB) Viewed 3093 times
Frame Changes
To clarify, what I am trying to determine is if there were any changes to the 305 frames/body over the course of the bikes manufacture and if so, what they might be. More specifically could I take the tail end off a 68 for example and weld it to my 61 and have it mesh? Thanks in advance for any suggestions you might have. Cheers!
The VIN is C77-e100045 according to the registration. As I am pretty new to this, does that give any clarity in terms of the year?
Re: CA77 305 frame changes ?
1964. ..........
I think that design has the back half of the finder spot welded under the seat.
If it does you can get another frame and replace your cut off end.
Takes work. .................lm
canuckada wrote:The VIN is C77-e100045 according to the registration. As I am pretty new to this, does that give any clarity in terms of the year?
I am picking up the bike this weekend so I won't be able to check the VIN info until then. Thank you everyone for your input thus far - what a wonderful community of support.
I'll keep you posted. Cheers!
