11.4 volts !
abert51
11.4 volts !
Post by abert51 » Thu May 22, 2014 3:38 pm
now that the CL is running on the road (finally) I may have an alternator issue to sort out. Testing at the battery bike off = 12 volts but with bike running it is only 11.3 t 11.4 volts. I am not sure about the cloth wraped wire (red covering with white wire in it?) running from the harness to the ignition switch. I got it wired to the ignition switch lug that is red and white. The test light does not light up with the key in the on or off position when I check for voltage at this (the red and white) terminal. The wiring diagram shows a wire running directly from the rectifier to the ignition ket switch. hope I got the wiring right but can anyone clarify whats to be done to sort this out. Much appreciation. I'm running but discharging....Bullocks! Thank you all.
mike in idaho
Post by mike in idaho » Thu May 22, 2014 5:54 pm
The diagram I looked at shows a red/white wire going from the rectifier to the switch terminal marked ch (charge?), then to the battery. A separate fused wire(red) goes from the battery post to the switch terminal marked bat. Logically, the red/white wire would just go to the battery post from the rectifier terminal. The ignition/light circuits are powered by the red wire, there is no reason for the red/white wire to even be attached to the switch. Perhaps the red/white post on the switch is just a convenient way to tidy up the wiring harness.
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
my company car is a Kenworth
