Hey guys I am new here and need some help. I am restoring a 1965 CA77 dream. I am wanting to install a new throttle cable, but the bike has an internal throttle twist grip thing, and I do not know how to remove it. The manual I have does not cover, so I am at a loss. Can someone tell me how to change the cable?
TOOLS
Changing throttle cable
Welcome to the forum., are you also active on the www.hondatwins.net ?
To replace the cable you have to disassemble the switchgear which holds the throttle grip.
Switch
When you take the switch apart be very careful. There is a little flat spring in there that applies pressure to the throttle tube. It will fall right out and will be hard to find. The voice of experience speaking...
