batteries
joey7478
batteries
Post by joey7478 » Tue Apr 29, 2014 6:42 pm
Does anyone use a agm battery? I have the old style thats 7 3/8 x 2 9/16 x 5 1/2 . If you do where did you get it?
OldStan
Post by OldStan » Mon May 05, 2014 10:50 pm
I installed an YTX7L AGM in my Dream about 2 years ago. Its smaller than the original, but has plenty of cranking power. I run with the headlight on no problem. I made some adapters and used some extra rubber so the wiring could be protected from shorting on the bracket. I picked it up on eBay. I plan on using one on the CL77 I'm putting together. It was under $30.
63 CA78
nevernotbusy
YTX7L AGM Replacement
Post by nevernotbusy » Tue May 06, 2014 7:39 pm
OldStan, any chance you could show us your adapter and rubber fittings? Seems like this battery is a no brainer, but would love to see how to seat it comfortably in the housing.
Thanks!
L
lrutt
Post by lrutt » Thu May 08, 2014 11:12 am
OldStan wrote:I installed an YTX7L AGM in my Dream about 2 years ago. Its smaller than the original, but has plenty of cranking power. I run with the headlight on no problem. I made some adapters and used some extra rubber so the wiring could be protected from shorting on the bracket. I picked it up on eBay. I plan on using one on the CL77 I'm putting together. It was under $30.
+1 on this size and capability. Works great. Same solution here as well with the foam blocks. When I bought a Shorai battery for one of my other bikes it came packed in a box full of these great foam pieces to pad things up for undersized batteries so I used that. That structural type foam used for things like pool noodles works real good for this. doesn't hold water but holds it's shape and doesn't crumble.
OldStan
Post by OldStan » Sat May 10, 2014 9:23 pm
Just got a chance to take pictures. I used an old truck mud flap for the rubber. The brackets were cut out of a piece of square tubing. Notice the right bracket is bent back slightly for clearance.
Now I'm looking for a narrower version for my CL77.
63 CA78
joey7478
Post by joey7478 » Mon May 12, 2014 10:54 am
what year is your bike mine take the smaller battery?
OldStan
Post by OldStan » Mon May 12, 2014 6:23 pm
Mines a late 63 (CA78 frame.) It takes the long narrow battery.
I'm ready for a battery for my CL77, realized the one I'm using the CA77 won't fit, too wide.
Haven't been able to locate an AGM that will fit. There is a Li-Ion available, but I'm leery about the charging, although I have installed a regulator. Also there's the price, about $100.
63 CA78
