Tough shifting from 1st to 2nd?
dickjewells
Post by dickjewells » Fri May 02, 2014 12:02 am
I have a restored dream and new clutch cable but shifting from first to second is a nightmare. I have seen other post stating the forks could be bent and a mechanic friend of mine stated that the these old bikes needed certain type of oil (not synthetic) could the oil be the issue or should I have someone check the forks. Any idea on the cost of replacing the forks would be greatly appreciated.
Richard
Re: Tough shifting from 1st to 2nd?
Post by LOUD MOUSE » Fri May 02, 2014 6:50 am
The forks in these engines don't bend.
They wear at the gear contact area.
At times a 1st to 2nd shift problem is due to worn shift rollers and/or shift drum. ............lm
dickjewells wrote:I have a restored dream and new clutch cable but shifting from first to second is a nightmare. I have seen other post stating the forks could be bent and a mechanic friend of mine stated that the these old bikes needed certain type of oil (not synthetic) could the oil be the issue or should I have someone check the forks. Any idea on the cost of replacing the forks would be greatly appreciated.
Richard
