pos. 2ND GEAR IS GOING TO KILL ME
apophis
Post by apophis » Sun Mar 30, 2014 10:42 pm
@Hoosier Tom. what do you mean by cotters? shift fork pins? (24261-253-010)
rrietman
Post by rrietman » Sun Mar 30, 2014 10:43 pm
worn dogs on 2nd gear and you can't always tell about shift forks at a glance. yes, you could get two (or five) used gear sets and all have the same problems. oversize cotters are the fix for the gear dogs. and really take a close look for galling on the shafts.
good luck
Randy
Hoosier Tom
Post by Hoosier Tom » Sun Mar 30, 2014 10:56 pm
There was std 23941-250-010 and 2 offset cotters, 23941-259-305 and 23943-259-305. Look at your parts manual and read Bill Silver's write up.
HT
apophis
Post by apophis » Sun Mar 30, 2014 11:41 pm
I did not replace the cotters
http://www.berkeleyhondayamaha.com/fich ... detail.asp
Is this something I can still buy new? should I put in std or OS?
48lesco
Post by 48lesco » Mon Mar 31, 2014 8:31 am
Just so there's no confusion when you search for these, they are "offset" cotters and they come in two varieties, .020" (23941-259-305), and .040" (23943-259-305). I'd go straight to the .040's. None are available from Honda, but they are out there. Try hondarestoration.com, Western Hills, hondanuts.com, etc. Here's a series of snaps with the .040's installed; the offset cotters just move the stationary gears closer to the sliders they have to engage with.
-48
5 Fourth.JPG (144.61 KiB) Viewed 3356 times
4 Third.JPG (141.42 KiB) Viewed 3356 times
3 Second.JPG (142.07 KiB) Viewed 3356 times
2 Neutral.JPG (141.06 KiB) Viewed 3357 times
1 First.JPG (141.46 KiB) Viewed 3358 times
apophis
Post by apophis » Mon Mar 31, 2014 11:26 am
so far I have only found someone with the .020's . still looking
apophis
Post by apophis » Mon Mar 31, 2014 11:50 am
I found a place that still has the 23943-259-305
Based on the microfiche of the trans, I need (4) of these cotters correct?
