                    A CL72 Project Starting To Move
I really like my Caswell home zinc plating set up.  It allows me to restore motorcycles at my own pace as opposed to taking all of the fasteners and other parts into the plating shop at one time. You can also take the time to repair damage to bolt heads.  Also, if you absolutely do not want to go to the chrome plater for that one last part, you can make it look very close to chrome by carefully polishing it and then zinc plating it!
- Brake arm bolt after zinc plating at home
 - image.jpg (45.54 KiB) Viewed 2384 times
- Brake arm bolt before plating
 - image.jpg (60.71 KiB) Viewed 2384 times
Meanwhile, I have acquired another project-a 1966 (I think) CL77. It's pretty complete, but also pretty clapped out. The guy I bought it from says it has an aftermarket big bore kit bumping the displacement to 337cc. It's got incredible compression and starts right away, but seems to have some carb issues.  My CL72 project is still moving slowly. The motor is in Texas getting rebuilt and I will be de-spoking the rims for rechroming soon.
- My CL72 waits for the engine rebuild
 - image.jpg (93.85 KiB) Viewed 2369 times
- A new project. A 1966 CL72 (it has almost 29,000 miles!)
 - image.jpg (80.9 KiB) Viewed 2369 times
I think that is a 67 issue.
Your bike parts are looking good.
All engine parts are cleaned and some blasted. . ............lm
Ray Smith wrote:Meanwhile, I have acquired another project-a 1966 (I think) CL77. It's pretty complete, but also pretty clapped out. The guy I bought it from says it has an aftermarket big bore kit bumping the displacement to 337cc. It's got incredible compression and starts right away, but seems to have some carb issues. My CL72 project is still moving slowly. The motor is in Texas getting rebuilt and I will be de-spoking the rims for rechroming soon.
I had some significant rust pitting on the fork pipe right where water probably collected and sat near the fork seal. I decided I better not risk it and get a new one.
- Ahhh, a NOS fork pipe! Look at that box...look at that wrapping paper!
 - image.jpg (77.88 KiB) Viewed 2371 times
- Red alert! Excessive corrosion on the fork pipe.
 - image.jpg (64.13 KiB) Viewed 2371 times
