Stator insulation damage
- malcolmgb
This is the stator on my CL72, there is some of the insulation missing, It was like this when I dismantled it with no signs of any impact damage on the outer cases. Is there any static resistance checks I can do since it will be sometime before the engine will be rebuilt and I can check the output from it. Can I cover it with anything to prevent any further damage or deterioration.
- S4010831.JPG (98.56 KiB) Viewed 1748 times
1977 CB400F
1973 CL175
1976 XL175 - Sold
1964 CL72
1966 CA78
1973 CL175
1976 XL175 - Sold
1964 CL72
1966 CA78
Re: Stator insulation damage
Not to worry.
As you can see all wire contacts all wire so not to worry.
I usually add some clear RTV to make it look better. ........lm
malcolmgb wrote:This is the stator on my CL72, there is some of the insulation missing, It was like this when I dismantled it with no signs of any impact damage on the outer cases. Is there any static resistance checks I can do since it will be sometime before the engine will be rebuilt and I can check the output from it. Can I cover it with anything to prevent any further damage or deterioration.
