Stuck muffler defuser
Does anyone have a tip for getting a stuck defuser out of a CA78 muffler. The left one slid right out. The right one won't budge and I am concerned about breaking the little tab across the end. Thanks.
Re: Stuck muffler defuser
No pearls of wisdom?garncarz wrote:Does anyone have a tip for getting a stuck defuser out of a CA78 muffler. The left one slid right out. The right one won't budge and I am concerned about breaking the little tab across the end. Thanks.
Remove the fastening bolt.
Spray with penetrate fluid.
Tap on outer edge in a twisting direction back and forth with a punch.
Use plenty of fluid.
May need to punch it in a little but keep twisting as you add fluid. ........lm
garncarz wrote:No pearls of wisdom?garncarz wrote:Does anyone have a tip for getting a stuck defuser out of a CA78 muffler. The left one slid right out. The right one won't budge and I am concerned about breaking the little tab across the end. Thanks.
