Funky Shifting
JagerMeisterChief
Funky Shifting
I have a 64 Ca77 with shifting issues. I can go up in gear just fine but when I go to downshift, I end up in neutral instead of a lower gear. I must then upshift back into gear and then I can downshift gears. This happens consistantly. If I hard shift down by not holding in the clutch, it downshifts normally.
Any Ideas??
Any Ideas??
JagerMeisterChief
Probably some wear on the inside depending on oil changes, shifting habits, etc. I would first pull off the clutch cover and the clutch to get a look at the shift ratchet and detent mechanisms. You can also turn the drum by hand then. If you've never been in there, here's what it should look like...
- 305 Shifter.jpg (458.4 KiB) Viewed 5095 times
JagerMeisterChief
JagerMeisterChief
JagerMeisterChief
