Question??
cushmanscooter
Question??
Is there within the forum a written procedure for adjusting the cam chain tensioner on the DREAM?? If so, any way to find it without so much hunting?? Thanks
Re: Question??
Loosen the tension bolt.
Remove the rotor cover.
Turn rotor with bolt while watching tension shaft.
When you see the shaft at the deepest tighten the bolt..... .......................lm
cushmanscooter wrote:Is there within the forum a written procedure for adjusting the cam chain tensioner on the DREAM?? If so, any way to find it without so much hunting?? Thanks
