CL72 high rpm issue
In most cases irregular sputtering issue's are correlated with the ignition, regular sputtering is often correlated to carb issue's. It's not a law, but certainly not coincidental.
Is this sputtering regular or irregular ?I'm not sure about the gearing or specifically how many rpms it reaches before it sputters
Update
I pulled the carbs and brought them over to Davo to look at and he helped point out a host of possible causes that might have caused problems ( thank you Davo - you are a river to your people) - I am now 99.9% sure it's carb related. Took the crusty filters off of the fuel line banjos, cleaned out all the vent holes in the carb, replaced the slow jets, etc. I put the carbs back on and had some backfiring on one side, so I'll pull that carb and check it again, but I'm optimistic....
Stay tuned...
Stay tuned...
For example, when the bike is warm, and you pull the choke a bit while riding it starts to sputter constantly, and will not stop sputtering as long you stay in a certain rpm range.
btw, my advice is to clean the carbs ultrasonic, works like a charm.
regular sputtering means constant sputtering, at a certain rpm range it will sputter constantly, irregular sputtering at a certain rpm is like it sputters for a few seconds, then it pulls, sputters again, pulls, etc. But I admit, you have to hear it to recognize it.Jensey - could you describe regular vs. irregular sputtering? Isn't sputtering irregular by definition?
