CA77E rear tire
belize2020
CA77E rear tire
How do you remove the rear tire on a CA 77E? I think it's a 64 model.
Put on the center stand.
Remove the axle nut - left side
Remove the rear brake stay (left lower side) - Or remove the rear brake lever - leave nut and brake rod intact.
Remove the brake adjusting nut.
Remove the brake rod.
Remove the axle.
Remove the spacer left side.
Slide the wheel to the left to get past the rear damper.
Slide wheel out the side of the fender.
I think that's it. With a little wiggling you should be able to get the wheel off and leave the rear sprocket, hub and damper.
Remove the axle.
belize2020
CA 77E Rear Tire - which side?
When you say, Left side, where are you standing in relation to the bike? Looking at it from the front, of from the rear?
Thanks.
Thanks.
belize2020
new inner tube
Thanks - we got the tire off.
Know I need to know where I can get a new inner tube. The one I have says it's 2.75/3.00 - 16. model # is 370163.
