I have a '67 CL77 that I just recently got running. Replaced most of cables, but still waiting on clutch cable (current one is quite stretched out, but seemed to work).
Took bike on test drive a few days ago. Ran well, had a hard time getting into a gear. I can't recall if it was second or third. I'd estimate I was going 15-20 and trying to upshift if I remember correctly. It happened twice in my run around the block whilst shifting. It felt like I absolutely could not get into the higher gear. Revs up/down Clutch all the way in and pressing as hard as I could. It eventually went and when it transitioned, it seemed smooth in that gear. It somewhat reminded me of a bike with a centrifugal clutch and having the clutch maladjusted and really having to stomp on it or get it just right.
Here is where I am now. Someone welded the shifter arm, which I cut off and am getting ready to replace. 5 disc clutch set is apart (disc at 2.65mm). Do I need to place the shifter linkage in any specific way? Also, is there anything else I should look for? I have some new discs, but the old ones don't seem to be too horrible (new are 2.75 mm or so).
I'm asking because if my problems are symptomatic of a gear problem, I don't want to put everything back together only to have to split the cases later. Any suggestions? I was thinking that MAYBE my clutch isn't fully engaging/disengaging bc of a bad cable, but not sure. I should have got the symptoms better, but I had pulled the case apart to do the shifter shaft and figured it would just be a worn clutch.
Any ideas/suggestions are greatly appreciated.
Shifting issue, bike apart ... may be able to use any tips
Re: Shifting issue, bike apart ... may be able to use any ti
If you have the engine apart I'd like for you to call me.
If you can do that now I'll PM my number to you. .......lm
mips wrote:I have a '67 CL77 that I just recently got running. Replaced most of cables, but still waiting on clutch cable (current one is quite stretched out, but seemed to work).
