How to Test Starter Motor? (Off bike during rebuild)
305explr
Post by 305explr » Mon May 21, 2007 8:14 pm
I just want to make sure the starter motor is working before I introduce other variables like wiring, etc. Can anyone offer any advice on how to do this? (i.e. directly from the battery?)
Re: How to Test Starter Motor? (Off bike during rebuild)
Post by LOUD MOUSE » Tue May 22, 2007 1:02 am
I use a 12 volt car battery charger. ..............lm
305explr wrote:I just want to make sure the starter motor is working before I introduce other variables like wiring, etc. Can anyone offer any advice on how to do this? (i.e. directly from the battery?)
305explr
Testing starter motor off-bike
Post by 305explr » Wed May 23, 2007 9:20 am
Thanks for the solution. For those who have a battery tender that _also_ helps start, that may be the ticket.
Because my tender is _only_ a tender, here's what I did: I took it to an auto parts store that tests starter motors. They hooked it up (+ to post on starter; - to ground - it took 2 tries for that. In the second attempt they clamped the - to the underside or far end of the starter itself). Then they held it down so it didn't spin out of control, gave it juice and VROOM! Off it went.
I imagine there must be auto part stores w/testing stations in/around most towns. Hope this helps folks.
kustommusic
Post by kustommusic » Wed May 23, 2007 9:33 pm
305, Yes, alot of battery chargers now don't have a big honkin transformer in them any more. So you must use a battery or a good old timey charger to test things like starters. Glad you were "thinking on your feet" and took it to a guy with a real tester. Steve Greer
cbxmountainman
starter testing
Post by cbxmountainman » Thu May 31, 2007 4:32 pm
You just simply ground the starter body to the negative post of a battery and hit the large cable to the positive post. If OK, it will spin freely.
