CA77 Petcock Removal
Dogsbd
- Contact:
Attempting to get petcock off of gas tank. Removed the bowl with 17mm socket, removed the screen and rubber gasket but the 3 phillips screws will not budge.
I don't want to destroy the screws getting them out, any tips on getting them to loosen up?
screws
might be time to invest in a impact driver
short of that , a #2 philips on a 3/8 extension and a T handle.
put the tank on a seat cushion, down on the floor so you can really lean on it.
If that don't get it, drill the heads off. those should be std 6mm you can get at most hardware stores.
Joe
Joe
