PDO::ERRMODE_EXCEPTION, PDO::MYSQL_ATTR_INIT_COMMAND => "SET NAMES utf8mb4", ] ); // newest completed CA entry (via view) $sql = " SELECT model_year, model, ADM_StateOrProvince, ADM_Country, condition_value, opinion_value_today FROM h305_ca77_entries ORDER BY submitdate DESC, id DESC LIMIT 1 "; $row = $pdo->query($sql)->fetch(PDO::FETCH_ASSOC); // casing helpers (same pattern as CB / CL) $keepCaps = static function (string $w): bool { return (bool)preg_match('/[A-Z]{2,}/', $w) || (bool)preg_match('/\d/', $w); }; $word = static function (?string $w) use ($keepCaps): string { if ($w === null || $w === '') return ''; if (strpos($w, '-') !== false) { $parts = explode('-', $w); foreach ($parts as &$x) { $x = $keepCaps($x) ? $x : ucfirst(strtolower($x)); } return implode('-', $parts); } if ($keepCaps($w)) return $w; $dot = substr($w, -1) === '.'; $base = $dot ? substr($w, 0, -1) : $w; $done = ucfirst(strtolower($base)); return $dot ? ($done . '.') : $done; }; $title = static function (?string $s) use ($word): string { if ($s === null) return ''; $s = trim($s); if ($s === '') return ''; $t = preg_split('/\s+/', $s) ?: []; foreach ($t as &$x) $x = $word($x); return trim(implode(' ', $t), ", "); }; if (!$row) { $line = 'Latest Registry Entry: No completed entries found.'; } else { // location like "WA, Australia" $region = $title($row['ADM_StateOrProvince'] ?? ''); $country = $title($row['ADM_Country'] ?? ''); $loc = trim( implode(', ', array_filter([$region, $country], fn($v) => $v !== '')), ', ' ); // normalize opinion_value_today using the same rules as CL: // - >=1000 => use as-is ($12500 => $12,500) // - 100..999 => treat as dollars ($750 => $750) // - 1..99 => treat as thousands (6 => $6,000) // - otherwise => "Not Entered" $valFinal = 'Not Entered'; if (isset($row['opinion_value_today']) && $row['opinion_value_today'] !== '') { $n = (float)$row['opinion_value_today']; if ($n >= 1000) { $valFinal = '$' . number_format($n, 0); } elseif ($n >= 100) { $valFinal = '$' . number_format($n, 0); } elseif ($n > 0) { $valFinal = '$' . number_format($n * 1000, 0); } } // condition code translation — same dictionary as CL plus "Rat" $condRaw = $row['condition_value'] ?? ''; $condMap = [ 'E' => 'Excellent', 'Exc' => 'Excellent', 'G' => 'Good', 'Goo' => 'Good', 'F' => 'Fair', 'P' => 'Poor', 'Par' => 'Parts Bike', 'R' => 'Restored', 'Res' => 'Restored', 'Rat' => 'Rat', ]; $condNice = $condMap[$condRaw] ?? ($condRaw !== '' ? $condRaw : 'Not Entered'); $line = 'Latest Registry Entry: ' . ($row['model_year'] ?? '') . ' Honda ' . ($row['model'] ?? '') . ' — ' . $loc . ' — Condition: ' . $condNice . ' — Value: ' . $valFinal; } // stamp + UTF-8 $built = (new DateTime('now'))->format('Y-m-d H:i:s T'); $stamp = ""; $charset = ''; $html = $charset . "\n" . $stamp . "\n" . $line . "\n"; // write to shared include $jobDir = __DIR__; $includeDir = '/home/mstoic3/public_html/shared/include'; $includeTmp = $includeDir . '/latest_ca77.tmp'; $includeDst = $includeDir . '/latest_ca77.html'; $jsonPath = $jobDir . '/latest_ca77.json'; $logPath = $jobDir . '/logs/latest_ca77.log'; // future optional if (!is_dir($includeDir)) { if (!mkdir($includeDir, 0755, true) && !is_dir($includeDir)) { throw new RuntimeException("Failed to create include dir: $includeDir"); } } if (file_put_contents($includeTmp, $html, LOCK_EX) === false) { throw new RuntimeException('Failed to write temp include file'); } if (!rename($includeTmp, $includeDst)) { @unlink($includeTmp); throw new RuntimeException('Failed to move include into place'); } @file_put_contents($jsonPath, json_encode([ 'line' => $line, 'stamp' => $built, 'ts' => date('c'), ], JSON_UNESCAPED_UNICODE)); echo "OK\n"; } catch (Throwable $e) { error_log("[generate_latest_ca77.php] " . $e->getMessage()); if (function_exists('http_response_code')) { @http_response_code(500); } echo "ERROR\n"; exit(1); }
1961 CB72 parts needed
giuliettashop
Post by giuliettashop » Sat Nov 17, 2012 2:21 pm
As the title suggests, I'm looking for some of the rare CB72 parts...
Correct levers
Tail light - everything but the lens
rear shocks -the ones with aluminum shrouds
while I'm at it: aluminum front fender!
Finders fee's gladly paid. Help my motorcycle become complete!
I'm in Oakland, Ca.
Paul Strassmaier
Post by Paul Strassmaier » Sat Nov 17, 2012 4:20 pm
I just found my aluminum fender this week, and those shock 6 months ago, so don't lose hope! I'll keep watching for you! The other thing I noticed is that the 61 cb72 rear brake and speedo cables are black, not gray. Keep in touch! Paul
CB72, CL72, CS72, CYP77
C71,JC57,D, 4E, Z50m
giuliettashop
Post by giuliettashop » Sat Nov 17, 2012 4:26 pm
Thanks Paul. I keep an eye on eBay. but am not sure where else these parts might get posted other than right here.
While I'm at it -can anyone tell me what the difference between the air intake tubes is between the 61 and later CB's?
FluteTears
Post by FluteTears » Sat Nov 17, 2012 6:25 pm
Watch craigslist some times you will find a parts bike.
1974 CT90
1964 CA77
alan curtis
61 cb72 parts.
Post by alan curtis » Sun Nov 18, 2012 3:08 pm
hi all, i could also do with a pr of rear shocks with the alloy covers on..for my 61, has any one had any covers remade.
also has the handlebar grips been remade. alan
Paul Strassmaier
Post by Paul Strassmaier » Mon Nov 19, 2012 3:03 pm
The 61 intake tubes have bands and not springs, so the rubbers have the wider indentation where the bands go. Paul
alan curtis
61 hubs
Post by alan curtis » Thu Nov 22, 2012 1:10 pm
I have in eau claire MI a pr of wheels from a early bike, the speedo and the alloy ring in the pic, has been sent to me in the uk, but the wheels are still there, i know the rims are not great but finding the hubs are hard like all the parts on this bike, what i need is a pr of alloy shocks and the correct seat base, althought i have a couple of prs of seat brackets. only swops on these hubs..alan
Return to “Wanted - Parts | Bikes | Services”
