I think I would do it with the seal in place and try not to cover the top of the seal as you might need to replace the seal some day.Jlovvorn wrote:Thanks a ton guys!
Any idea where to source that clip?
Should I JB weld with the seal in place?
Or pop the seal out and JB it and then put the seal back in?
                    Chunk missing from engine case
- FluteTears
1974 CT90
1964 CA77
						1964 CA77
Thanks Jensen.
But to my surprise it is NOT leaking out of the seal with a chunk missing.
Once I got it good and clean, I discovered it is leaking from behind the washer on the gear shift rod.
I assume there is a seal back behind the washer, but how do I get to it?
There seems to be a retaining ring holding the washer on, but it goes all the way around the rod, and I dont see how to remove it.
Thanks for all the help so far.
Take a look at this schematic.
http://www.cmsnl.com/honda-cb160-sport- ... ml#results
I think that you are looking at parts 21 and 7.
The seal is behind these.
									'60 C77 '60 C72 '62 C72 Dream  '63 CL72
Ok, I see it now, #21 on the schematic.
But my clip seems to go around 360, and I dont see how to get it off.
http://honda.eastbaymotorsports.com/fic ... veh=132814
[/img]
[/img]
