Crankcase cover grease fittings...
Are the GREASE FITTINGS, on the drive side crankcase cover of a CL, PRESSED or SCREWED in. If any of you have allready done this replacement, I would appreciate any advice. Thanks
BTW, I removed the one on the case by using a GOOD pair of small vise grips, gripping the thin flange right next to the case itself. Care must be taken though not to gouge the case with the jaws of the grips. You might mask off the case with masking tape prior to trying to remove the fitting. I twisted and pulled at the same time. It came right out. Same method was used on the swingarm pair. Good luck.
Gary
Gary
'65 CL77 Owner
