Post
by dagersh » Sat Sep 15, 2012 9:25 pm
OK,
I dug in a bit more into the wiring harness. If you reference the pics above, the weird switch in the headlight bucket acted as a simple on/off on the RED Main Beam wire. On top of that, the red wire coming off the Probe Engineering EI unit is also spliced on this same circuit. The result was that if you switch to the low beam, the power to the EI was shut off, and the motor shut down.
My assumption is that the Red wire will not have power to it without the lighting switch on top of the nacelle supplying power to the Red wire... I could however be wrong.
I am thinking this because the red wire has no power as it comes out of the left hand switch, which controls the High/Low beam and the horn.
Here is my second assumption: The Black/White wire on the harness is switched power. Wouldn't this wire be where you would want to supply power to the EI? A further assumption would be that the red wire going into the Probe EI supplies power to the unit. The rest of the wires in the Probe EI are Black,Blue, Yellow and Green. This being so, the red wire is the only wire going into the bike's harness.
Anyway - I am just throwing ideas out here. Everything works, except for the horn, but I will get to that after I know the EI is functional.
As always, thanks for your input.
Gersh
