sarals
Post by sarals » Sat Jul 28, 2012 4:15 pm
jerry wrote:Dear Sarals, Since you will be splitting the cases for your new transmission installation I strongly suggest you get the bottom case welded. You will have total peace of mind regarding the integrity of the repair. Just have the 2 case halves bolted together when welding is done and distortion will not be a problem. With careful cleaning up of the welded area on the outside of the case nobody would know of the repair. All the best Jerry
Jerry, that's a great suggestion! I'll see if I can have it done. Thanks!
1965 CB77 305 Super Hawk
1989 NT650 Hawk GT
1981 Yamaha XJ550 Seca
sarals
Post by sarals » Tue Jul 31, 2012 6:51 pm
I pulled the rotor today and discovered that my starter clutch had disintegrated. That's what I said! All three screws had snapped off, the backside of the rotor is essentially ruined, and most of the sprague clutch innards are nowhere to be found. So, I need to find a good used rotor and starter clutch.
1989 NT650 Hawk GT
sarals
Post by sarals » Tue Jul 31, 2012 7:00 pm
On the other hand, when I got the cases split, I discovered that my transmission is in EXCELLENT shape. The 14mm bushing shows no wear, nor does the kick starter pawl. The shift forks are perfectly okay, and all of the dogs look just fine, as well. Now, why did I buy a new transmission? Well, I'll put the new transmission in the cases, but first some major cleaning needs to be done. If anyone spots something I didn't, or has suggestions, please, I'm more than happy to hear them!
By the way, the ding in the right front of the bottom case barely intruded into the inside, so I'm going to clean that up and put some fresh JB Weld on the inside of the case - but yes, I'll see if I can have it welded first.
1989 NT650 Hawk GT
Hoosier Tom
Post by Hoosier Tom » Tue Jul 31, 2012 8:37 pm
Sara,
It looks like your 14mm bushing is shot. I am attaching a photo of what a new one looks like. That ridge on mine measures 19.92mm diam. It looks like yours is worn to a nubbin. I believe that ridge acts like a thrust washer and keeps the counter shaft from touching the low gear.
HT
sarals
Post by sarals » Tue Jul 31, 2012 11:55 pm
You're right, mine is toast! The ridge is much smaller than that, clearly worn. It looks like the transmission I bought last month will go in the engine after all.
1989 NT650 Hawk GT
jensey
Post by jensey » Wed Aug 01, 2012 2:26 am
Not everything what shines is good. Kickstarter pawl ?, I would replace it without hesitations.
14 mm bushing ?, just like Tom said, it's shot. Did you draw your conclusions on your transmission with the eye or with a pair of callipers ?
When someone is for the first time in an engine one can be overwhelmed with joy and happiness, because everything seems to be in nice shape, and draw the conclusion that it is ok. But everything runs in oil, so it is clean and as long you don't see heavy damage, it doesn't mean it's ok.
Solomoriah
Post by Solomoriah » Wed Aug 01, 2012 7:51 am
Hmm. Your original posted pictures show 18182 miles on the odometer; my Dream has over 19,000 miles. So I suppose I'm looking at some transmission work as well...
