Name that Part!!!
jgentry425
Name that Part!!!
Post by jgentry425 » Tue Apr 17, 2012 8:25 am
Hey guys,
I have a 67 CL77 that is my first project, let alone my first motorcycle. I took the head apart to replace the gaskets and piston rings, then put it back together. While mounting the engine, I found this part, and can't figure out what it goes to. The engine is back together, so I'm hoping this is easy to put back on without tearing it back down. Any advice would be very helpful.
JG
67 CL77
rzgkane
Re: Name that Part!!!
Post by rzgkane » Tue Apr 17, 2012 9:22 am
Did you take apart the clutch? That looks like the piece that mounts to the outside of the clutch assembly at the end of the clutch release shaft.
jgentry425 wrote:Hey guys,
jgentry425
I didn't take apart the clutch
Post by jgentry425 » Tue Apr 17, 2012 9:37 am
We left that crankcase intact, but we did take the clutch cover off to replace some oil seals. Could it have come off without taking the clutch apart?
I've already gasketed and closed the clutch cover back on the crankcase, but I have not filled it with oil yet. Can I take that cover off and reuse the gasket?
JG
67 CL77
68Cb77
Post by 68Cb77 » Tue Apr 17, 2012 9:41 am
look here......
http://www.cmsnl.com/honda-cb77-super-h ... E++06.html
That part sits in the middle of the clutch......it's spring loaded somehow too.....can't exactly remember.......but check for the spring too
Yeah, the gasket will be fine
67 Honda CB77 Superhawk
82 Honda XR200R
70 Honda CB750 K0
68Cb77
Post by 68Cb77 » Tue Apr 17, 2012 9:43 am
Actually, you might not see the spring, but it seems to me when you push the part back in, it should have a spring behind it that keeps it pushed out a bit......
82 Honda XR200R
70 Honda CB750 K0
jgentry425
Excellent,
Post by jgentry425 » Tue Apr 17, 2012 9:43 am
Thanks guys for your help!
JG
67 CL77
rzgkane
Post by rzgkane » Tue Apr 17, 2012 2:19 pm
Yup. He's got part # 13 in his hand. Spring is (or should be) inside the shaft that runs through the middle of the clutch assembly.
68Cb77 wrote:look here......
