1964 CA77 idle issue
JagerMeisterChief
Post by JagerMeisterChief » Sun Apr 01, 2012 11:33 am
Just started working on my new Dream. It is having a hard time idling which I think is because it came from Florida and is now in Utah. The altitude is making her run rich. Any tips on getting the idle to smooth out?
Last edited by JagerMeisterChief on Sun Apr 01, 2012 12:34 pm, edited 1 time in total.
Post by G-Man » Sun Apr 01, 2012 11:47 am
Beautiful looking bike you have there. Welcome to the forum. When you get a chance, please put your location in your profile and you may find help locally.
If you do a search here on the forum you will find plenty of help for your carburation issues.
bloodweiser
Post by bloodweiser » Sun Apr 01, 2012 12:54 pm
Pull the plugs and figure out if it's running rich before you go messing.
Then if it is, find the mix screw and lean it out until it stutters then turn it the other direction (while counting the number of turns) until it stutters and finally put it half way between those two points.
pknopp
Post by pknopp » Sun Apr 01, 2012 7:14 pm
Yes, more info is needed. Is it actually running rich or does it just seem to be? Has it been running O.K. or has it been sitting and someone just now got it running?
Does it run better when you clean the plugs? What color do they get after running it?
JagerMeisterChief
Post by JagerMeisterChief » Thu Apr 26, 2012 10:07 pm
Turns out the Petcock was plugged up. Hardly any flow of fuel to the carb. Cleaned out the petcock and now it runs now but I am going to get a rebuild kit for it.
