The Superhawk from hell...
Hahnda
Post by Hahnda » Mon Mar 26, 2012 8:10 am
Check your carb floats for leaks. May not be the issue but its another thing to cross off the list.
Jlovvorn
Post by Jlovvorn » Mon Mar 26, 2012 8:30 am
Added. Thx
Keep em coming.
hillhudson
Post by hillhudson » Mon Mar 26, 2012 9:37 am
Are you 100% sure both carbs are cb77 carbs ? one isn't stamped "CL" on the side ?
'65 s90
'64 ca95 dream
'65 cb160
'66 cb77
Jlovvorn
Post by Jlovvorn » Mon Mar 26, 2012 10:29 am
I explored this before, at your suggestion, and didnt find CB77 anywhere except on the choke lever.
Where would it otherwise be stamped?
Also, I see some threads about coils overheating and giving out.
The idle dropping way down when hot is consistent with one side dropping out.
What is the correct Dyna coil replacement for a Superhawk?
I want to swap out the entire ignition when my electronic ignition arrives in the mail.
Maybe its a coil pooping out when hot.
hillhudson
Post by hillhudson » Mon Mar 26, 2012 2:06 pm
here is a pic of where it will be stamped on both carbs other than the choke lever.
Screen shot 2012-03-26 at 11.47.26 AM by beatboxer89, on Flickr
'65 s90
'64 ca95 dream
'65 cb160
'66 cb77
Jlovvorn
Post by Jlovvorn » Mon Mar 26, 2012 2:10 pm
Nice!
Even I should be able to handle this job.
Will check in a few hours.
Jlovvorn
Post by Jlovvorn » Mon Mar 26, 2012 3:55 pm
Thinking of ordering up some Amal carbs and bolting them on - just to see what happens.
Crazy and excessive?
Or bold and decisive?
